3v cams
HorseOnRoids
Blue Indigo
Kingsville Tx
What's up guys, I know this topic has been beatin to death I've found some real great info on here about the blower cams. I just can't decide on which one will be good for my set up. I have a 07 with a Paxton 2200sl 10psi, 4r70 trans mvb, 3.90 gears. Im going to be getting the heads ported at fox lake (stage 2 port) I just can' decide on the cams. Comp cams 127550 or lunatic cams 21270716
RocketcarX
95% of my weight is fuel
Colorado
What does your tuner think? You can’t go wrong with Comp stuff, however Lunati makes a great product too. I think you’ll find most folks experience centers around Comp if you are looking for people that have run those cams.
46addict
13726548
Lawrenceville, GA
Are you installing a loose converter? What's the target RPM range?
Since there is room to pulley down I would just run more boost instead of doing cam/head work if it were my car.
get a custom grind from L&M - call Mike tell him what your goals are with the car and he'll set you up
HorseOnRoids
Blue Indigo
Kingsville Tx
The converter I have is 4000 4c w/ LU from circle d. Rpm 6500-6800
