4 different 02 codes
WhiteS197
I have thrown in this order
P0171 System Too Lean cleared it led to -
P0135 O2 Sensor Heater Circuit cleared till -
P2195 O2 Sensor Signal Stuck Lean cleared to finally get -
P0053 HO2S Heater Resistance
Its not my daily so Ill take it out after trying a step and if that didnt work, id start over. (checking vacuum leaks, cleaning maf etc... then leave it parked a couple days)
the only thing I did was probably over oil a damn K&N. (it was a new can of oil and I get heavy handed) I did the MAF cleaning procedure with electronics cleaner.
It runs fine wide open, but at cruising speeds it cuts ups and is real jerky, and at a stop the idle drops and almost shuts off.
I guess Im down to just replacing the o2, but wanted to make sure I am not missing anything first.
