4R70W
retfr8flyr
The Old One
Providence Forge, VA
I am selling a 4r70w trans and converter setup for a friend. I bought the trans from a member on here for my friend. The trans is from FB Performance, setup with a manual valve body, trans brake and overdrive, doesn’t include the overdrive or lockup module from FB. Here are some specs on the trans.
Billet steel direct shaft
Competition hi flow mvb and high pressure regulator
Hi performance clutch packs and high energy band
Large servo assembly
Modified front pump assembly w teflon rings
Overdrive/lockup and optional- trans-brake activated electrically
Ultra light stamped steel drum assemblies
The converter is a 3500 stall Circle D triple billet lock up converter, still in the box. The trans has 6 passes and about 500 street miles. The reason for selling is because the car it was going to be installed in has been sold. It includes a new TCI Thunderstick shifter but you will need the shifter cable and mounting hardware. The trans is still sitting in the FB shipping container and will be shipped in that container, to prevent damage during shipping.
I have additional photos if interested. Asking $3000 plus shipping.
Earl
EDIT
Here are some additional pics but without my name in them.
Earl
1fast05
I wanna go fast
Gulfport Ms
Damn good deal, I need my T-56 sold and I'll be taking this!! Guess I need to drop my price to get it sold! So how much is the module that it needs?
retfr8flyr
The Old One
I'm not sure I'll have to call FB. I think it's around $80 as it's just an electrical module not the valve body or anything very expensive.
Earl
1FAST3V
Is this the lentech 4r70w ? And what kind of power will it hold?
retfr8flyr
The Old One
Update.
I talked to FB today and the kit they use for the OD and Lockup, with full instructions, is $195. You can operate the trans as is, by just wiring it up with switches for the OD and lockup but the kit they sell is a much better setup and automatically takes it out of lockup when you push in the brake pedal and other advantages.
Earl
TexasBlownV8
Formerly TexasBlownV6
Central Texas
..one of the pics is a duplicate...
And I'm waiting on a couple other specific pics; ty :)
Can someone identify the 'sensor' at the back rear of the passenger side?
