devin2589
bought a saleen supercharger kit used. hooked everything up. but throwing a check engine light for the MAF and AIT sensor. does anyone have a diagram for it? I tried searching on here but couldn't find it.
Because you don't just want more air, you want a MAF sensor that allows more air flow without peggingYeah why would you not use the stock in a 90mm FRPP or Steeda CAI, works fine!!
Now, to the OP's question.
Look here
Belt slip?
exactly what i needed. thanks.
car's up and running but i'm only seeing 6psi with the needle fluctuating quite a bit between 5 and 6psi. it's a 3.4 pulley so i should be seeing 9psi. any ideas?
mods:
saleen supercharger with 3.4 pulley. 90mm ford maf. c+l intake elbow. steeda filter. 39lbs injectors. pypes lt with o/r x pipe. kenne bell bap. jdm tune.
Look here
bought a new belt and was doing the same fluctuation as before. found out the belt was rubbing on the alternator bracket. ground the bracket down a little bit. no more rubbing. now the car holds 7psi and spikes 8psi at 5000 rpm's. although i thought the 3.4 pulley was supposed to be good for 9.5psi? possibly lower because of the long tubes and no cats?
