ABS Connector pinouts
ESP41
My google fu has failed me. Can anyone provide me or point me in the direction of the pinouts on a 2005 Mustang abs module connector and also a 2010 connector? They are definitely different.
Story: I bricked my late production 2010 abs computer on the racecar(SCCA CP car- stripped to metal). Even the dealer cant get it to work. Part(AR3Z-2C219-b0 is unobtanium, especially since it is a late build (09/09).
ABS module cannot connect to the RCM(Restraint Control) module- so no abs.
Buddy has his old 2005 System that doesn't need all the advancetrac stuff to work, so I plan on installing it as a standalone system to get me through September, them upgrade to a better system (PK60?, Bosch if I hit the lottery)
Thanks
ESP41
NM - Found them. Now I just need to get it installed.
86GT351
Sunny South Florida
Suggestion for you. If you have something you can post with a schematic that might help others, post it for future searches.
ESP41
Good point. Let me see if I can get it to fit in a doc.
ESP41
1st image post is a 2010 ABS connector. Note the middle row does not exist on the connector
The 2nd post is a 2005 ABS Connector.
Note the additional wires on the 2010 for the Steering position and Yaw sensors.
ESP41
I did confirm my (2010) car will start with the ABS connector unhooked. So I will try to graft in the 2005 ABS computer (block and motor too). I will not hook up the CAN wires. Should be interesting to see how well it operates as a stand alone system.
Remember this is for a race only, not street legal car.
