ABS problem.
gray1622
Norman, OK.
MY abs light and red brake light keeps coming on when I hit bump or under hard breaking then turns right off. I check brake fluid level, ABS rings and sensor for damage, connection on the sensor to the harness, and the harness around the axle. I recently change both front wheel bearing still have the same problem. It cant be fuse or relay right? If it was the light would just stay on. I am thinking I must have bare wire some where but for life of me I cant find it. Anyone have any suggestion?
gray1622
Norman, OK.
So I went to brakes place and there diagnosis tool couldn't communicate. What does this narrow my list too? ABS module?
Yeah probably, same thing on my car. I have had my abs light on for a long time. I plant to just delete the abs eventually.
