one eyed willy
Pizzle fo shizzle
AEM boost controller !!SOLD!!
SOLD!!!!
AEM tru boost controller / gauge slightly used 30-4350
This gauge is like new,it was used for about 3k miles, works flawless.im switching to something a little more advanced.it comes with box, gauge,solinoid,fittings,extra bezel and faceplate, pretty much everything just like as if it where new, i kept the box and all the goodies when i installed it and still have the changable face plate and bezel for it.you wont get a better deal!!
these retail for $335...selling mine for $225 shipped in the 48 states.
TRU-BOOST Gauge-Type ControllerFAQs...AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
Legal in California only for racing vehicles which may never be used upon a highway.
No external interface required for programming!
Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
Quick connect technology eases the installation process
Two user selectable boost settings with peak boost memory
Scramble boost setting allows user to momentarily change boost levels
User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
One (1) low-side output included for warning lights
SOLD!!!!
