MrBhp
- Joined
- Sep 12, 2013
- Posts
- 1,259
- Reaction score
- 1,038
My underhood insulation has been laying on a shelf for 6 years. Took it off to paint the hood. No wreck. Just fixing extensive rock chips. No problems so far.
It was still sealed off from oxygen if it was still corroding. Leaving the bubble on was a mistake. Most start under the edge of the hood and spread to the top. The trick is to remove them before they do. None of the bubbles I removed ever returned. Most of them were smaller than a dime when I removed them and exposed the bare aluminium to the air.
Compared to many other metals aluminium has good corrosion resistance. This is because aluminium develops a thin oxide layer on the surface when the metal comes in contact with oxygen. The oxide layer protects the aluminium against corrosion and if it is damaged, it will immediately regenerate, provided there is oxygen present.
https://www.alumeco.com/knowledge-technique/general/oxide-layer/#:~:text=This is because aluminium develops,provided there is oxygen present.
Good old fashion zinc-chromate primer/sealer if you can find it. Been used on aircraft for a hundred years.
If you notice the bubbling early enough, it is clear that it started at the edge of the sheetmetal. Next to the spotwelds. Iron contamination or not, if you sand and spraybomb the underside before it reaches the leading edge, outside paint damage can be stopped.
Ps:it is not just mustang hoods that do this.
Pps: what about the flaking white paint on crown vics, and vans....but I digress...lol
