RSKtakR
i have no trans mods at all.. and just a CAI.
I was one with this issue. They replaced my tranny do to me and said it was easier also cause the parts for the tranny are harder to get then a new tranny. They said that a synchro did go out. Mine did same thing as yours as well. Would kick out and would only go in with some nasty grinding. Mine did finally start going in fifth and staying in it but still with nasty grinding. Mine would grind sitting still trying to go into fifth.
My dealer was cool with mods i had. Servcie manager has a gt500 that has work and agreed with minor stuff i have done shouldnt have went out already. If you can take back to stock though to avoid any issues.
Ford has come out with a Service Bulletin for the grinding now that entails switching trans fluid.
I would not put a TR-6060 in there. They are riddled with problems and not very strong. The T-56 magnum is the beefed up version of the 6060 and is a MUCH better transmission. There are a ton of internal differences.
My MT82 is a bit notchy but doing ok so far, I'm really thinking of trying the T-56 upgrade if it goes out.
With the .5 overdrive of the T-56 I would not be surprised if we could get 30-32+ mpg at 65mph even with 3.55 or 3.73 gears.
switching to the thinner fluid will make any whining that is allready there louder.. and the new fluid wont help the issue's that this trans has.. MY trans whines from 1st -4th, like a twin screw is under the hood, grinds on the up and the down shift to 5th, also grinds sometimes going into 6th.. the trans is notchy and clunks around like you wouldnt believe.. allready had the entire clutch assembly replaced.. goes in for the trans next week.
I agree, and the Service Bulletin I saw posted on another forum said to replace trans fluid with what owners book says is already in there to replace the fluid everyone says should be in there ...........
MT82 has been used for years in other applications, so I think it is more to it than the fluid used too. I think there is something in that goofy shifter linkage setup causing issues too.
r.barn is right. The TR6060 is just as problem riddled. I had one, so trust me. I don't want another one. So far my MT82 has been great.
Car is going in monday man....been out of town for work. Hope they replace it for you.
Threads like this are why I shy away from brand new, first year model, cars
-Will
Actually the syncro assembly also keeps it in gear
same problem as the T5.. when to much torque is applied parts start to fail.. HOWEVER in this case we get a trans that is only rated for 369lb-ft of torque and I know my car is makeing 385lb-ft stock, so its under rated from the factory before it even has any miles on it as is which doesnt help.
I love seeing these posts. Please don't tell my or lethal's transmission that he is only rated for 369#'s.
I'm sorry if you are having problems with your car, but the transmissions are pretty damn strong. Much stronger than the 3650 and are the best manual transmission ford has ever used.
