I've driven on track...
A stock T-lock.
An extremely tight rebuilt T-lock with carbon clutches (GT500 style).
A Torsen T2R.
And now a Wavetrac.
What I learned...
A stock T-lock is fine for street tires, but as soon as you put sticky track tires on there, it will just burn up in less than a day on track.
A rebuilt, tight, carbon clutched T-lock isn't much better, as it only lasted 2 weekends on track with R-comps.
A Torsen T2R is an incredible upgrade for tracking. The ability to put the throttle down so much earlier without the backend drifting is nothing short of amazing. I really didn't know a rear wheel drive car could put the power down so early... And that was on the old 4 link + PHB setup my '97 Cobra had. I don't know about long term reliability since I sold the car shortly after. I do know that Ford Racing offering the Torsen T2 as well as the T2R has to say something. I would like to think that they worked out the metallurgy issues years ago since you really don't hear about them failing. Maybe go over the the Boss forums and talk to those guys?
The Wavetrac... A very similar experience to the T2R, but with a few nuances. I'm still getting used to the grip available on early throttle corner exit. It's truly like driving a different car. On slower, tight corners where the inside rear usually gets more or less unloaded and a typical diff applies no power, I can 'feel' the Wavetrac work here, almost a slight pulse or something as the outside gains more power and helps to rotate the car, but not only that, I can also tell the inside wheel is no longer rapidly free spinning. The T2R did this as well to an extent, but whenever I fully unloaded a wheel with the T2R, you had to wait for it to become loaded again before power was really being put down again. I went with the Wavetrac over the T2R this time for the warranty, and well, as an early adopter, have already paid the price.
You see, Wavetrac provided 2 different sized C-clips for the install, one .5mm ID narrower than the other. You are supposed to use the tightest fit. My installer (at a big time Mustang shop), unaware to anyone else, ran in to trouble with the C-clips, and damaged the tighter ones trying to install them. He took it upon himself to try and 'narrow' the others and install them anyway. Well, with less than 100 street miles, my first track day out quickly ran into problems. After warming up and starting to get a feel for the new setup, I started to get more aggressive and took the race line, hitting the T3 curbing at Road Atlanta. My ABS and Traction control lights turned on. I took it easy for the rest of the lap and pitted. A quick search showed the likely fault was an ABS sensor, so I cleaned everything and double check the connectors. Reset the ECU, and went for a test drive, everything seemed OK, the lights were off, and I decided to go out for the next session. After a couple warm up laps, everything still seemed OK, and I started to push it again, I'm not sure this time where the LIGHTS CAME BACK ON, as I was in some 'fun' traffic (See GT3's), but I noticed once I had some space on the back straight, at about 120 mph. Knowing I needed to pit, I lifted and gave a couple point bys... then braked coming down the hill for T10a...
Almost Disaster! The rear pinched and locked up, sending me spinning straight off the corner. When the dust settled, I was pointed exactly 90* toward T10b, only a few feet off track, no contact with any walls, and I even lucked out of hitting the gravel trap! Checked with the corner worker behind me and gave a thumbs up and after cleared, headed to Pit... SQUEEK! SQUEEK! Rear, Brakes? were screaming. I pulled it apart to see what was going on. I could tell the rotors CONTACTED the caliper cradle. When I pulled the rotors, the axle moved A LOT. When I pushed and then pulled on the hub/axle, the whole axle CAME OUT. Checked the other side... Same thing. I think to myself, "You mean the caliper bolts were the only thing holding the wheels on the car?!" I counted myself lucky the 'incident' wasn't worse and went to see the Installer. Apparently the guy that did the install no longer worked there... unlrelated... but after the owner tracked him down, he admitted to the botched install, and the the shop went about taking it apart to see what's what. The c-clips were in the bottom of the housing floating in oil... yay. A quick call to Wavetrac with the part # for the tighter clips in hand, and they tell us that they no longer make those! WHAT?! Apparently they had a lot of issues with them and redesigned them into a new C-clip design, with a wider thickness and much tighter fit. Great, we'll send those on there way... A couple days later, the car was back together and better than ever. The shop made it right, and now has some more experienced staff with Mustang road race setup knowledge. I can't get back the missed track time, and I ended up bending and cracking the two front wheels in the 'Off', but I'm thankful it wasn't worse!
It's unfortunate that Wavetrac and Moser did not contact early purchasers to the design change of the C-clips, had they done so, this probably wouldn't have happened. The same can be said for the Mustang shop, had the installer made aware any issues, we could have called Wavetrac then and found out then and gotten the new C-Clips.
That's my story. For better or worse, it looks like I'll be with the Wavetrac for the long term. It's performance is great, and it's makes no added noise (no rear interior + heim joints everywhere isn't quiet anyway). If I run into more issues, atleast I know it's covered.
