Very possible. Need to hook up the gauges and document pressures.
If it is cycling more often than normal it is possible that the refrigerant charge is a little low.How frequently does the A/C clutch cycle? I keep hearing a clunk every 20-30 seconds and it sounds like its coming from the right side of the car. Clunking clutch bad news? The car is still cooling, but seems a little weak.
It has an orifice tube and they have factory installed fluorescent dye.Used to design automotive a/c systems for a living. By far the most troublesome part is the expansion valve if it has one. Is the line cold after the expansion valve or orifice tube?
It can lose some refrigerant over time through the compressor shaft seal.The car has 125K miles on it and has only had the AC system opened once, to check the pressure. Is a loss of pressure over time normal, even if there are no leaks in the system? I'm going to drop by my cousins shop next time I'm in the area to have him measure it for me, vs picking up one of those cans.
