Anyone know where to buy 1" vacuum caps?
Jeffs FRC
Bartlett IL
I converted my Paxton setup to a blow through and need to block off the recirc outlets. Im having a little trouble locating some 1" rubber caps to do this...
Here is one of the outlets I need to terminate.
I have an assortment of vacuum caps, but only up to 5/8" i.d. Here is a pic of the largest cap I have. If anyone knows where I can find something like this with a 1" i.d. I'd really appreciate it!
bullitt boy
NJ
If you can't find one use PVC cap and some silicon sealant. You could also use a plastic cork from a bottle of cheap champagne in a pinch, just don't drive after consuming the champagne.
Jeffs FRC
Bartlett IL
Thanks, but someone on my local forum pointed me in the right direction. Just ordered some from McMaster Carr. Not sure why I didn't think to check there in the first place...:idea:
Plastic cork huh? You must have a degree in African engineering.:laughlots:
bullitt boy
NJ
I worked in a shipyard repairing tugs and gasoline tankers that were of a vintage age some built in the 1920s we used everything at our disposal to keep them running.There was quite a bit of Yugoslav engineering going on as that was the majority of our work force those guys waste nothing.
IMHO I wouldn't try to cap something that large thats gonna be under boost.
I would cut it flush and weld it shut.
