470 GT/CS
- Joined
- Apr 7, 2009
- Posts
- 1,218
- Reaction score
- 6
My dad is going to have Comp cams and Kook's LT's installed on his GT/CS soon. My dad and I wanted to get the Comp SPR Stage 1 cams(127400), but the shop the cams will be installed at recommended the Comp NSR cams(127200) because they do not require valvetrain modifications; another reason they mentioned is that it will cost a lot more to install the SPR's.
The NSR's cost $650-$700, while the SPR's with springs, retainers, and phaser limiters cost $1200-$1300 depending on where you buy them. Then there's the additional labor to put in the new valvetrain to sustain the higher lift of the SPR's which would add at least another $500. If I'm correct about the additional labor costs, that is a total of over $1000 more spent to have the SPR's.
Taking this into consideration, are Comp SPR cams really worth forking out the extra dough for? For a little perspective, my dad's car is not taken to the dragstrip very often at all, it has 3:73 gears, and I don't know if he ever plans to purchase ported heads.
Current performance mods are C&L 95MM Racer CAI, FRPP 3:73's, 93 octane tune, CMDP's, and UDP's.
Note: I did spend quite a bit of time using the search function before I decided to post this thread.
