Thinking about relocataing the battery to the trunk and I would like to hear from those that have done it to see if you felt it was worth it and would you do it again.
I know one of the pro's would be moving 40-45 lbs off the nose of the car and either centering it on the rear or placing it over the passenger side; I am running a KB BAP and twin 405 fuel pumps so I could eliminate the additional wiring for the FPDM's since I have a dedicated line for the FPDM's coming off the battery now...I could reduce that amount of wiring as well as stepping up the gauge since the distance to travel would be drastically reduced which theoretically would reduce load.
Thoughts?
Thoughts?
