benefits of upgraded blower
chad05gt
Lake Charles, La
07torchgt
^MY NAME; THINGS I SAY>
ya'll might wanna read this, then Ill be ready for recanting...
x boost, is x boost :asshat:
recanting what... on a 9.8:1 compression engine 10 psi is 10 psi whether its from a D1 or P1... sure 10 psi is different on a low compression motor but he isn't comparing different engines... he is comparing what eith would be like on his stock motor
james432
east moline IL
well u wont see 10psi all the time not unless your are in the 5500-6400 rpms all the time...if you go to a 4 pulley your probley see 7psi at that rpms...
silverstang07
Honestly on a stock bottom end you don't NEED a D1...............hell even built motors most peope can still get by with a P1.........P1 is capable of over 600, thats a fact. EVEN if you build the motor, what kind of power do you look to put down?! Most people I see are only in the high 5XX RWHP area. The p1 will do everything you need, for less money, and do it alot more efficiently. I'm not saying the D1 is a bad piece, because its not. Its better in a few ways. But I spent MONTHS researching prochargers with some folks that happen to own one of the fastest procharged mod motors in the world, and thats the way I look at it now.
