Best bumpsteer kit??
Lee's05GT
Formally Qksixx
Tacoma,Washington
Looking at getting a bumpsteer kit for the car, Ive been doing some searching but havent really come across which kit is good or bad ect. ect. Ive had my eye on the steeda kit, QA1 kit and UPR bumpsteer kit. Has anyone had any issues with either of the kits? Pros? Cons? Thanks!
RedMosesSC
NYC
I had the Steeda kit on my last GT, i swapped it along with a full suspension build so i cant say how it worked on its own. Unless you feel bump steer or your drastically lowered i dont think its necessary.
BMR Tech
Traction Vendor
Tampa, FL
I can add, we have had excellent luck with the QA1 kits.
I have not tested and/or used the other kits mentioned.
Hope that helps some!
Lee's05GT
Formally Qksixx
Tacoma,Washington
Well my tie rod ends are shot and thought about getting a kit instead of putting OEM ones back on. I was thinking I might as well even if I do not need it.
Sent from my ADR6300 using Tapatalk
RedMosesSC
NYC
THe Tie ROd's are adjustable, i had the Steeda kit, i dint bother to swap it over to the Saleen and i do not notice any Bumpsteer. But, yeah.. YOu may as well replace it with something built to take the abuse...
Lee's05GT
Formally Qksixx
Tacoma,Washington
That was the idea.
BlueDevil
BOOSTED!
I went with the Steeda kit because I was on sportlines. Quality parts, well made. It's not fun setting up the spacers, though. Will be the same with any brand.
