Best N/A Tuner ???
UNICORN
hello guys .
my friend wants to know who's the best N/A tuner ? . ( with almost 200 shot).
these are his parts :
1-JLT Air Intake.
2-Hooker Ceramic Coated Longtube Headers with X pipe
6233-1HKR and 16684HKR.
3-Borla Stainless Steel Aggressive Cat-Back Systems
140135.
4-Steeda UDP System
701-0005-A.
5-Ford Racing Composite High Flow Intake Manifold.
M-9424-463V.
6-Comp STAGE 2 XFI SPR (Spring,Steel Retainers & Phaser Required) 3 Valve Cams
CCA-127500,CCA-26125-24,CCA-5449,CCA-700-24 .
7-Ford Racing 39lb Fuel Injectors (Set of 8)
M-9593-M39 .
8-Ford Racing GT500 Fuel System
M-9407-GT05 .
9-MSD Blaster H.O. Coil On Plug Kit
82438 .
10-Nitrous Express 3 Valve Plate System
20947-10 .
( he want to run 200 shot) .
hope you can answer me as soon as possible
thanks .
08gt4u
first a 200 shot is out of the question without a built motor if he wants it to last more than a couple of runs.
second if he decides to lower the shot and with all the mods he have he needs a dyno tune.
KungFuHamster
Ft Worth
so is he more concerned with the NA tune or the nitrous tune? make sure you post vids of when he sprays that 200 shot...i wanna see.
UNICORN
what about a 150 shot?
it will be safer right ??
killr3v
Hector G.
Katy, TX
Just messin. For real though, 200 is way too much and he is just gonna be crying all over again when the motor blows. Needs internals even with race fuel.
