Best OEM tire replacement
Michael55123
St. Louis, MO
06 Gt Premium with stock 17's, right now the Perelli's are on there last leg. What's a good tire to replace this with? What size should I run? Stick with 235/40/17's ? Thanks for any advice.
jha1223
Midwest
I've been wondering the same thing myself. But, I think there are a few things to consider - how are you going to use them? DD? Some track time? Year round (do you see any snow or sub 40 degree weather)?
Are you looking for something specific? If you could change something about the way the OEM's handle, what would it be? Do you have a budget?
fdjizm
Drag Queen
I have kdw's as well they are pretty decent. but anything comparable?
Jucostud
booooost'd
North of Dallas
Your factory size is 235/55/17;). If you are wanting to go bigger, 255/50/17 nitto's are a good choice.
killermustang
New Brunswick,Canada
i switched to Toyo Proxes 4 w/nitogen, and imo are better than the perelli's, plus they were a couple hundred less. i use them as dd from april til november
Chris B.
PA
There are quite a few things to consider...
Did you like the stock tires overall? Anything you would change about them?
What are your plans for the car? Any AutoX, 1/4 mile, or road course use planned? Do you drive it the car snow or rain regullarly?
coop6
Atlanta, GA
I plan on going to the track, does 275/40/17 on OEM bullet's work? What for the front 255/45?
tjm73
of Omicron Persei 8
Rush, NY
I ran 255/45R17's on my '98. They were a great all around tire. I am seriously considering them in the 255/50R17 size on my factory wheels for my '05. Relatively inexpensive too. If not those I may go to a BFG Touring tire as I would only run them on a trip because I plan to get Race Star's at some point.
coop6
Atlanta, GA
I want as much tire in the rear as I can fit. I eventually will upgrade to either a 10" or 11" wide wheel in the rear. If I go to 18's I'll probably go with Hoosier or MT.
