Bleeding brakes
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Quick question. After searching the internet I'd like to know how YOU guys suggest bleeding the front brakes. Do you start with the caliper CLOSER to the reservoir....ie....drivers side caliper first or the one FURTHEREST from the reservoir...ie...passenger side caliper.
I've never thought it mattered but I guess it does.:question:
AnotherS197GT
Serial Valve Dropper
USA
Since you are only replacing the front calipers, you might be able to get away with only bleeding the fronts. Passenger side first , then driver. If you are going to bleed them all, do it in the order Scott said.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Actually I believe the recommended approach is to do all four in this order - PSR, DSR, PSF and lastly DSF.
Just curious, but since the only air that should be in the system would be closer to the front brakes since that's all I changed. Would trying to bleed the back brakes introduce air bubbles all the way to the rear of the car which would make bleeding the system SUCK even moreso than it already does just trying to bleed the front only???
86GT351
Sunny South Florida
This is correct, Sequence is always furthest from the Master Cylinder first. Also if you are bleeding them by pumping the pedal it is very important that the person pumping the pedal does it slowly. Firm slow strokes of the pedal work best. Pumping the pedal too fast will cause aeration when the air bubble breaks up and now it is harder to remove the air!
ExSRT8Guy
Been There, Done That
Scotts Valley, CA
This.
And this. The advice to pump the pedal slowly is really good!
86GT351
Sunny South Florida
This.
Can't tell you how many times I have had guys I worked with in the industry that don't follow this and don't understand why they can't get a good pedal!
nyuk98GT
Infrequent poster
Chesterfield, MO
Darren,
Motive Power (motiveproducts.com) makes a handy little pressure bleeder - don't need a second person to help. I used one for my old '98 GT and it made brake bleeding a lot easier. I don't know if they have the cap for the +2010 Mustangs but a phone call would get that question answered pretty quickly.
HTH,
Chris
JEWC_Motorsports
S197 Junkie
Texas
Darren please make sure the brakes are bled properly. I dont want to wreck the car on my way back to Texas!
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Darren,
HTH,
Chris
Thanks Chris. A guy local to me has been nice enough to lend me this exact product.
Again, thanks for all the input too guys especially the order of calipers to bleed.
loots06
Monterey CA
Darren when you bleed the brembo start with inside bleeder and then the outside bleeder. I only bled the front brakes.
Boaisy
Dark Knight
Memphis, TN
I have a Motive, and started from the Right rear. Also you will need to pump the clutch a bit too since it shares the fluid. I waited until the left front to pump the clutch.
RocketcarX
95% of my weight is fuel
Colorado
Broscience
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Thanks a million! I was talking to the guy I borrowed the Motive bleeder kit from and we weren't sure on this.
Thanks!!!!
loots06
Monterey CA
Just to be safe you might want to cover the caliper with blue tape to protect the paint. Also keep a spray bottle of water near by in the event you get brake fluid on the caliper. This will help neutralize the corrosiveness if you get a spill or drip. That's what I did and I'm glad I did. Before you start make sure the bleeders are tight.
hamish
B.C.
Strange, I was always taught to do the front left first.
