Blew the rear end at the track
06GTMustang89
Corner Carver
Cary Area, NC
Didn't even get out of 2nd gear she caught traction and blew up oil everywhere...any ideas for a bullet proof rear end?
don_w
Dyno Numbers - Who Cares?
San Diego, CA
My TrueTrac finally gave up the ghost, so a Detroit Locker is going in as I type....
06GTMustang89
Corner Carver
Cary Area, NC
The pinion shaft flew on the track so I know my housing is shot...should be interesting to see it when I get it out in my garage I will be posting up pics for sure
RetroGT2006
06 S197 Member
Florida
Wow that sucks, but you gotta pay to play.. Just a perfect excuse to mod it =). Interested in the pix when you get the car back.
06GTMustang89
Corner Carver
Cary Area, NC
exactly found a new take off axle housing fully assembled for 711$ ill throw in a tru trac...put 4.56's back in the car and im good to go...
the pictures are going to be pretty awesome actually i have a feeling there is a pretty big hole in the bottom of the housing...not thrilled this happened but this is racing...if you aren't breaking shit you ain't goin fast enough i guess
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
If I was starting from scratch (which sounds like you might be doing) I'd at least do some research on some of the bolt in 9" housings. I still like the 8.8 myself but if you're starting with nothing, I'd at least look into it.
RedFire07GT
11sec N/A 3V
Ocean County, NJ
Good to see everythings working out for you. the 8.8 is very strong too, im surprised yours went. a truetrac is a nice mod, i run one myself and it works everytime!
Like above said, now you have an excuse to build it stronger!
Brandon
Fallenauthority
La Plata, MD
I agree, you're starting from scratch and you have to pay 711 just to start with a 8.8 again, might as well look into a bolt in 9".
Sent from my Droid using Tapatalk
chad05gt
Lake Charles, La
What you do at the end of the track is your own business...
Jokes aside, sorry about the carnage... NO better time to UPGRADE!?!
06GTMustang89
Corner Carver
Cary Area, NC
looks like the eaton posi gave way after a year....the spider gears and springs of it were all i felt in this hole..
iwaxmyjimmy
Greenville,NC
Man i thought the truetrac was stronger then the locker.
Read up on traction aids, the detroit locker is a much much stronger than the worm gear style tru-trac..... honestly the tru-trac is a POS and is alot like the GM design of the limited slips (F-bodys and what not)..... and yeah they stuck too in my opinion.
And nice vent hole in the housing....... does that increase MPGs??? I want to know more about this mod.
06GTMustang89
Corner Carver
Cary Area, NC
yeah i think im going to go with the detroit locker...and some moser axle to handle the added traction once i get the new housing...ill have the rearend out hopefully tomorrow and will provide the full carnage pictures
RedFire07GT
11sec N/A 3V
Ocean County, NJ
I have to disagree with you sir, i believe the Detroit trueTrac is not a POS... Infact, i really like mine, works evertime and i trust it 110%. Im not bashing you at all, just stating my opinion on the product. The Locker is a great unit as well, which ever the OP goes with he will not be dissapointed.
Basically the difference between the Locker and the TrueTrac is, the Truetrac uses a worm-gear as u stated and the Locker uses a clutch.
Brandon
iwaxmyjimmy
Greenville,NC
Brandon
Granted its not really a POS it does work, but I'm just one of those purist kinda people and I'm all for a full on locker. Its simple and damn near bomb proof. I come from more of a back ground building jeeps, trucks, and what not and I have installed a few tru-tracs per owners request and they later put detroits or ARBs in them. And when they go boom... its really really bad and most the time nothing is salvageable, from my experiences with them. And redfire are u running a really sticky tire?
06GTMustang89
Corner Carver
Cary Area, NC
i just really don't know which to go with to be honest...shes a weekend driver and goes to the track...i do like corners on occasion...i just don't know the pro's and con's between the two...
RedFire07GT
11sec N/A 3V
Ocean County, NJ
I can see where your coming from with the offroad style vehicles and using a locker over a truetrac. Both are made form the same company so i would trust both. & yes i run a Mickey Thompson DR at the strip. Alls im stating is whichever the OP goes for, he wont be dissapointed.:clap:
Brandon
