BadPiggy
Hooligan Ahole
Guys,
Installing a shitload of parts from BMR. Right now I'm tightening everything down and I run across this situation. Wondering what to do and I know many of you are running the K, too.
I have the K bolted down to spec, now tightening all the add-on parts. I'm not sure how critical getting the K centered is. The 4 bolts under the motor appear to be offset a small amount. In these pics you can see the small space that I'm referring to. I'm wondering if I need to stop, loosen the K bolts and ever so slightly shift the K, motor attached...just enough to center the body holes. All 4 of these bolts have just about the same space showing.
My main concern is the K being able to eventually open the holes up and creating a helluva problem.
Do I run with it?
Or do I stop, loosen bolts, shift it?
Is it that critical?
I'm running adjustable BMR A-arms if that matters.
Do I run with it?
