Boost controller on centri?
BruceH
BBB Big Bore Boss 322
How do you switch from low boost to high boost without the use of the mbc?
Have the low boost spring in with the control line hooked up normally. To inactivate it just move the signal line to the other banjo fitting that's used for a boost controller. That should keep the wg closed? I haven't done it yet. I'm really happy with 14psi. Any reason why that wouldn't work?
05stroker
Never enough power guy!
Bullard Tx.
No, just asking if that is what you are doing. I had an issue with my Trueboost once (due to my install) and I moved the line on the waste gate to run full boost as you describe. It is in the thread I linked above. Just trying to keep it apples to apples...
msczesny1186
New Jersey
With the boost controller can u hook it up to the existing boost gauge? Or do u have to use the kit? Kinda have a hard on for my cobalt gauges lol
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Can you hook what up to the gauge? I don't understand the question. Having a boost controller doesn't mean you can't still have a boost gauge.
05stroker
Bullard Tx.
The gauge is the controller you can run a manual boost controller with what you have now it is just a valve that you turn with your hand in line between the vacuum port and the wastegate.
gizmo5
Italian between my legs
I'm thinking about doing this so I don't have to change pulleys when I wanna run hard.
Sent from your moms room...
Sinner
Plano, Tx
i'm leaning towards the eboost2 but it looks to the a pain in the ass changing boost settings. i don't like overly complicated things, lol
05stroker
Bullard Tx.
Its supposed to be nicer then the Trueboost but the Trueboost only needs one button pressed to change between low boost and high boost.
tjm73
of Omicron Persei 8
Rush, NY
Interesting read. I've often wondered why not pulley a centri set up to make boost build superfast and just bleed off what you don't want.
If you have two setups and one is set to make 15psi max and the second is set to make 30 psi max. Does the second blower make more boost sooner and lower in the rev range?
