I suspect with more tuning we will see it making more power starting in the 5k range. But overall, thats the kind of shift in powerband I expected.
With the rod ratio of the engines it seems like we should be able to take them up to almost 8k, but there must be some other limitation I dont know about, or nobody has really tried because up until this manifold has existed there hasnt been much reason to rev that high...
Also, you guys need to look more carefully at the voluem difference within the RPm range the engine will be in while racing. Id have to do som e gearing calculations, but assuming that youre not dropping much below 4500 when shifting up at ~7500 rpm, the torque volume lost below that point means nothing.
From 4500 to 5500 the loss in volume is pretty small, and the increased volume from 5500-7500 is substantial.
And thats still with what I expect is tuning that has yet to be optimized. When they start actually increasing peak power the volume will get much, MUCH larger.
