Brake help
StangPhD
Lumberton, Texas
Just installed a line lock. It holds when the switch is engaged but when it is off, the brakes are non-existent. Please advise.....
StangPhD
Lumberton, Texas
Yes it is. The line lock works. However, when the line lock is inactivated, the brakes are almost gone. Gonna take it to the shop in the morning. I can't get a helper to manually bleed this bitch very well. I could be a multitude of things.....air in the lines, air in the MC, vac leak. The shop will know.
gray06gt
Try bleeding the abs unit itself however you'll need a scanner for it
sounds like you need to bleed the system
