Nastystang06
Yea my clutch dont slip at all it is the 3 not tye 3 plus
Anyine know what the stock disk is made of?
Well, not sure why, all I know is most every time I see a broken manual tranny, there is a Spec clutch attached to it. Just something to consider...Yea my clutch dont slip at all it is the 3 not tye 3 plus
so you put a complete stage 3 clutch in, i really don't think changing the disk will help much as the clamping force comes from the pressure plate. have you thought about or looked into a Boss302 clutch kit? the boss seem to be able to hold a lot of power. might be worth looking into.
The problem with the MT82 is its torque rating of 383 ft lbs. The car comes from the factory with 390 ft lbs. How is it supposed to hold up?
Sent from my DROID BIONIC using Tapatalk 2
Call it what you want... It seems like the Specs have a hand at breaking transmissions, for whatever reason. Do searches. They're easy enough to find.The spec pressure to plate is very similar to stock just a little tougher
The torque rating on the T5 in the 4.0L Mustangs was 300. Myself, and many others went over that with no problems. One guy (Fazm) went through I think four transmissions (with a Spec clutch each time). Had nothing to do with his power level or the rating of the tranny.The problem with the MT82 is its torque rating of 383 ft lbs. The car comes from the factory with 390 ft lbs. How is it supposed to hold up?
I had the same clutch on my turbo 06 and bever had a problem.
I tore my transmission apart.
I broke all the teeth off 3rd, syncros and forks and everything else is fine.
