Jeffs FRC
The MAFia only adjusts the MAF readings and has nothing to do with the IAT readings... Ideally you want the IAT sensor after the intercooler for an accurate reading. Brenspeeds relocation kit comes with an IAT sensor that you install where you decide and comes with a wiring harness you splice into the harness from the factory MAF which also houses the factory IAT.So the mafia setup doesn't give it an accurate reading?
How many sets of springs has your car seen?I will probably switch the springs out for a set of BMRs or maybe the FRPP K-Springs.
