Bullitt #2479 Build
antonio1988
Redline: 8600rpm
Miami, FL
damn, thats cheap. $74.95 for front and rears. Whats the ride height on them?
all you need to know is that I have a friend with them and he's making quite a bit less power than I am (100 shot and no L/Ts and stock UCA and LCAs) and he just pulled off a retarded 11.59 in an auto. Those springs are incredible for drag racing, I'm buying a set and switching springs out the night before race days.
antonio1988
Redline: 8600rpm
Miami, FL
Ok so they are well worth the money then. Do they lower the car any? Or do they basically provide a stock stance.
basically a stock stance... I say that with the sheer awesomeness of your car and build, get some 15s front and rear with a 28" meat out back and slap those CJ springs on it and scare the living piss out of every single car that pulls up next to you
GrnBullitt08
Dale Jr
Northwest Indiana
Just gotta see how much a set of big a little are gonna set me back first. Don't really have alot of $$$ to play with since th build.
antonio1988
Redline: 8600rpm
Miami, FL
Jegs = about $1100 mounted and balanced for a complete shipped set
Racestars = about $1500 mounted and balanced for a complete shipped set
antonio1988
Redline: 8600rpm
Miami, FL
Where you getting those prices at Antonio? You have links?
the racestars are from BBR, tell them I referred you (Anthony) and speak to Chris. The Jegs are my guesstimation through a reputable wheel shop. Jegs wheels will run you close to $500 for rims and then $600 for tires, the Jegs may actually be closer to $1200 but shouldn't be more than that for a complete setup. I would personally go with the RaceStars, they're badass and light and have perfect fit, an 8" rim out back on a MT ET Street D/R 275/60/15 would fit perfectly out back, the 10" wide rim would poke out a little bit but on that one you could fit a 325/50/15
