Burnout Cleanup
C130Mustang
I was wondering what you guys use to not only cleanup after a burnout but to prevent the burnt rubber and VHT from sticking on your paint and in your wheel well. I've read that people have used products specifically made for it such as Geddex Burnout Guard, I've also read that people have used Pam spray, WD-40 among other things, but I am wondering what you guys have used to help make clean up as easy and quick as possible....
Thanks Jeff
dysan
Dis-Member
Williamstown, N.J.
What I usually try to do is put some wax on the rear panels behind the tires and don't wipe it off. After you're done racing you can wipe the rubber off with your hands and it just falls off.
C130Mustang
I've tried putting a fresh coat of wax on right before I go to the track but I wipe it off cause I am usually racing when it's sunny out and I'm not a huge fan of letting the wax bake on in the sun. But I've also read that putting the wax on and leaving it would help. Last time I just really scrubbed and then claybared it when I got home. I guess the main concern is the wheel well.
fdjizm
Drag Queen
s8v4o
I wonder the same thing, especially when I see racers with pristine paint. I've thought of using the masking tape as well. Although this probably belongs in the drag racing section.
gmantheman
Escondido, CA
I need to start using painters tape. I have tried PAM and other cooking sprays but when I go to wash the car, the VHT just seems to smear all over. I have gotten this stuff on microfiber towel then when I went to wash it, it got all over the washing machine and on to other clothes. I know use bug/tar remover and scott shop towels for clean-up.
Steedman07
Classified's Moderator:)
Connecticut
I am not a blue tape over my rear panel guy..I go to the car wash and use a high pressure soap and it comes right off. IMO, if your paint is protected, it will come right off..
fdjizm
Drag Queen
Painters tape works best, it doesn't leave a sticky residue behind and you just peel it off as a whole and throw in in the garbage when you are done. what could be easier? no wiping etc...
ozzy
Wolcott, CT
DupliColor Shield
The Shield from Dupli-Color provides temporary spray-on protection for your vehicle where bugs and road grime can do damage. It's ideal for the front end, rear quarter panel and rocker panels. Spray on Shield as a temporary bra for long road trips, quick mud flaps or as a bug guard. Shield sprays on easily and dries in less than a minute. And best of all, it stays on until you wash it off. You can power wash it off or use soap and water. Rain, snow or moisture in the air won't affect it. This product leaves no residue on a vehicle's paint. Give your vehicle the protection that it deserves with Shield.
ChevyKiller
Preferred Internet Drink
Yeah - painters tape here to when I used to care...lol
For the past several years though I just let it build up till it bothers me then I clean it.
08gt4u
i use the bug remover spray from walmart to get rid of what the water and soap didnt.
DKS
Wax on, Wax off.
VA/NC LINE
Thanks Jeff
You know, we have a "Keeping it clean" section here. Just saying. . .
DKS
Wax on, Wax off.
VA/NC LINE
Just like the bugs.
2SSARME
Banned
In your 3v
Pink spray paint works wonderfully.
Blue painter's tape works like a charm and won't do anything to the paint. I've done it a few times and all the z06s out at the track do too.
