Bushing saddles
msczesny1186
New Jersey
Hey guys. So I have a whiteline front swaybar and the bushings are a extremely tight fit. I have to literally crank the saddles down the the mounting bracket and I think I'm bending the saddle around the bar. I saw you sell a bushing saddle combo on summit racing http://m.summitracing.com/parts/upi-0048 I was wondering if this would work / help. Whiteline lists the bar as 33mm and those bushings/saddle combo is for a 35mm. I feel confident it will work but wanted to ask first.
Thanks
Mike
UMI Sales
Philipsburg, Pa
Mike,
If you're bar is 33mm I would avoid running anything that's not advertised to fit 33mm. If you have metric calipers you can measure the true diameter of the bar. Powdercoat build up may be a variance on your Whiteline bar.... 2mm of slop would likely wear that bushing out quickly and cause some unwanted knocking.
Thanks, hope this helps.
Zac
