cai/maf change
doc stang
It is my understanding that most of the horsepower benefit that comes form adding a CAI and 93 octane tune . . . comes from the tune, and the usually larger MAF included with the inlet tube. (think more mustang GT-ish, I had a C&L racer intake /vmp 93 octane tune on my GT before i got the bullitt)
Since the BULLITTs already have a CAI, is there a MAF which will work with out tube, and then a tune to go with, which would be cheaper than having to buy an entire CAI kit with CAI/MAF/new inlet tube?
thanks,
doc
cekim
Large Member
Earth
thanks,
doc
Not quite sure what you are asking, it is my understanding that the Bullitts already have a good intake and tune - I doubt you will see much benefit over that setup with a hardware change. Likely can squeeze out a few from the tune, but not as many as a GT would get...
"Upgrading" the MAF has no inherent benefit - it is just a sensor - so long as it is not saturating (and it will not with an N/A setup until you really work over the heads, up the RPMS and/or add displacement), then replacing it won't help anything...
All it tells you is how much air is going past it. If you already have a tube which minimizes the restrictions, then that's as good as it gets...
doc stang
anyone know what size the stock MAF on an +05 GT is?, vs what "most" CAI's (JLT,STEEDA, C&L,etc) upgrade it to??
my reason for asking is my 08 bullitt already has a CAI, but the inlet ttube looks closer to a stock GT's, than my previous C&L racer inlet.
so I am guessing the MAF is also probably stock GT sized.
I don't mind going to a 93 octane only tune, as thats all i buy anyway,
I already have a CAI stock on the BULLITT, but want to upgrade tunes, and MAF's (+/- inlet tubes)
BOTTOM LINE IS : i dont want to have to waste $ on the CAI part of the deal, sine it already has one.
doc
Booya
Pompano Beach, Florida
Steeda is 90mm, C&L street is 85mm and racer 95mm ... you already have the CAI, I wouldn't replace it. The only way you might see gains is if you get it dyno tuned with the higher octane.
65sohc
Fresno, CA
You might contact Doug at Bamatune. He did extensive testing on the Bullitt CAI a couple months ago. I don't remember which forum the results were posted on: either themustangsource or allfordmustangs.
