Can’t roll windows down.
Larryfishes53
Roseburg Oregon
I need to pull my doors off to paint the jams. Motor (and the associated power connections) is not in the car so I can’t power the windows up or down. Tried jumping them at the switch plug in but nothing moves. There are 5 possible connections, tried several combinations. Help!
Autokyrios
VA, USA
In an absolute pinch, unbolt the window pane brackets from the track and take the window out. Make sure you mark how they were aligned so you don't have to fight with it going back in.
As for the window motor:
Pins
1 - Up/down circuit
2 - Accessory delay
3 - Adjust switch feed up
4 - Adjust switch feed down
5 - Ajar switch feed
6 - Motor pulse data
7 - Voltage (hot all times)
8 - Ground
