Hollowdweller
- Joined
- Jul 10, 2018
- Posts
- 328
- Reaction score
- 37
That is very odd because Comp Cams does not recommend lockouts for all the 3 valve cams. I have run the 127350 cams for several years and one of their features is the variable cam timing is still active. Comp categorizes their cams in the catalog by wether they need springs, limiters or both.….I thought this was odd bcz surely I would’ve seen somewhere in all my research that all Comp Cams need lockouts
I would not relay on the tuner alone to prevent the valves from kissing the pistons. The man said he would run them locked!!!Called MMR and he said….
“Personally I would run them but it’s really up to your tuner”
I got the impression the guy was just trying to get off the phone. I was on hold for 40mins then when he picked up he seemed confused and distracted so I didn’t put much stock in what he said.That is very odd because Comp Cams does not recommend lockouts for all the 3 valve cams. I have run the 127350 cams for several years and one of their features is the variable cam timing is still active. Comp categorizes their cams in the catalog by wether they need springs, limiters or both.
Yeah I’m just going down the chain…forum said call comp, comp said call MMR, MMR said call tuner lol….MMR guy did say tuner may not want lockouts for timing control…I would not relay on the tuner alone to prevent the valves from kissing the pistons. The man said he would run them locked!!!
