car is running weird
06silverbullet
orange county, ca
Without codes or abnormal engine data it's pretty tough to even hypothesize what "could" be wrong or where/what could be the cause of the problem. There's been some pretty standard suggestions "clean MAF/TB" and check the datalog for anything that may stand out. Just because the car may be setting a new threshold for what you consider to be running rough, doesn't mean that it isn't just learning how to run again. Hell just the weather could be enough to throw off the baseline in closed loop. Depending on how modified, the worse it could be. Until it pops out some codes, I'd just give it the chance to learn. Now if you take it out and do some WOT pulls and it runs like shit, then I would be concerned. Something would have to change fairly significantly to throw off open loop.
i took it around the block before i replaced the altenrator and got on it a couple times adn it was gutless
if i take it out tonight i will try and record it with my phone
checked all the plugs and they looked fine, none were fouled or wet.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
what do i capture? settings? and yes the 02 sensors were unplugged and i did replace one that had gone bad recently a couple months ago. it was also the main o2 sensor, but that would have thrown a cel considering mine was just delayed on warming up and it threw a code.
i may wait til tonight and try crusing on the freeway for a little bit but i doubt thats going to change anything but would finally rule out the tune issue but i highyl doubt thats it
i getting really sick of this damn car, between last years engine harness frying and now this shit... getting over it and quick. miss my fucking 97 tbird atleast the damn thing ran no matter what
Sell me the damn car for cheap then! :roflsquared:
BruceH
BBB Big Bore Boss 322
no i don't i sent him a pm earlier.
i tried the stock tune and it still ran like shit, slapped the astock intake on but left the rest of the bolt ons on
Do you know what your fuel trims are? You can log them via the handheld or with livelink.
Why fuel trims you ask? They can point to a few things that might be happening because they correct a/f in closed loop from what's predicted to happen based on airflow.
If the trims are out of whack it means the fueling is off. If we can determine that fueling is off it helps to narrow down what's going on. An example would be excessive positive trims. This could mean that unmetered air is present and it's being compensated for with the fuel trim.
Trims should be within 6% (.06 for the log, 1.00 is 100%) in an ideal situation. If you somehow swapped the o2 sensor connections then the ecu would be correcting the wrong side and it would show up in whacky trims and a poorly running motor.
If I've followed everything correctly you have done a few wot pulls and are seeing leaner than normal afr, is that correct? If so then it points to unmetered air or wrongly metered air provided everything is correct with the fuel system. The maf is still used in open loop (wot) but the o2 sensors aren't.
By any chance did you put anything in the fuel that could be messing with things or changing the stoichiometric ratio of the fuel?
06silverbullet
orange county, ca
i believe my tuner talking to some other guys that use him turns off closed loop/learning.
yeah i did change the o2 sensor but that was a few months ago i assume that would cause immidiate problems no?
lito got into conact with me so i will be sending him a datalog tomorrow when i get home and see what he sees.
you are correct on the wot pulls. they seemed pretty lean from what they should be. they are in the 13.3+ range vs 12.5
i dont use any additives for fuel.
BruceH
Yes, it would of showed up right away, I was thinking you had unplugged the o2 sensors during the downtime for some reason. It's real easy to accidently swap them when hooking them back up.
He probably turned off adaptive learning but is still using closed loop. Sometimes people repeat things that they have heard and they aren't exactly what's going on. Logging long term fuel trims would be an easy way to check. If ltft stay at 1.00 then adaptive is off. It will still run in closed loop with adaptive off. Turning adaptive off keeps the ecu from learning bad habits. It's not usually done unless something in the motor setup is non standard and responsible for giving flaky readings. As long as there are short term fuel trims then it's in closed loop.
A big jump in afr to the lean side without changing anything would point to the maf or unmetered air. You cleaned the maf though. By any chance did you recently reoil the air filter if it's an oiled type? I ask because excess oil can contaminate the maf. A contaminated maf won't pick up all the air that's moving which will result in the ecu supplying fuel for less air than is being consumed.
Hope you get it figured out.
06silverbullet
orange county, ca
yeah didnt touch the sensors this time.
ok will look into that when datalogging a lot of good info thanks
ok well thats a good start to look at. i did clean the maf with maf cleaner i could spritz it again.
and no i use a dry filter
TexasBlownV8
Central Texas
Well, you were having a lean issue awhile back due to electrical issues. I wonder of those reared their head again.
TexasBlownV8
Central Texas
Might need to check the voltage at the fpdm's for the over-12v from the BAP output. Although that's probably not the issue since we wired it up right, it was an issue before. Sometimes things rear their ugly heads again. This would only be suspect if fuel pressure was dropping too low.
[EDIT: OOPS!!! WRONG MEMBER!!! Thought you were someone else! DOH! ..never mind!]
06silverbullet
orange county, ca
i dont have a bap, and i just replaced the fpdm about a year ago.
06silverbullet
orange county, ca
yeah should have done it from the get go didnt even think about it. lol total brain fartism
well fuck me sideways. i swapped the coil with the number 1 cylinder. to tell whether it was the plug or coil. still missed. changed the sparkplug with a spare one i had lying around. still not registering on the datalog. i assume i';m now gonna be fishing in the harness?
TexasBlownV8
Central Texas
You probably have a cut in the harness. The red wire on the COP plug should have 12v with key on; the other pin goes to the PCM and may be cut or broken. You make have to unplug the large pcm plug and check continuity to the #8 cop circuit (disconnect battery first).
You've narrowed it down nicely :beer:
06silverbullet
orange county, ca
just checked that the wire has 11.83 keyed on and that matches cyl 1
so which big ass connector do i need to pull from the bec to test that or does it pug straight into the pcm
so i'm slowly working on checking the trigger wire i assume is not working as it has power.
it's the white with a red marker. i'm fallowing the harness and i assume that the trigger wires split off into a squareish connector? just before the pcm between the pcm and the engine essentially
06silverbullet
orange county, ca
is this where i should be checking for contunuity or is it going to be the actual plug in the ecu. if at the ecu does anyone have a pin layout for that ?
