cschoening09
hope you get it figured out john. id like to see that car run sometime!
Do you have the top port on the wg vented to atmosphere? BOV vacuum line ran from intake manifold to top port on BOV(if it has two ports)?
BOV should be open at idle/part throttle and closed at wot. Try and test the wastegate diaphragm with a vacuum pump to ensure it isn't blown apart. Hook a vacuum pump to the top or bottom port and see if it leaks.
If the wastegate is unhooked from both ports and the compressor port is blocked it will build about 8psi.
If the compressor port in run to the top of the wastegate with the bottom port open it goes as high as you'll let it. Smoke test didn't reveal any leaks
Is that the large yellow 10psi spring? Diaphragm does not appear to be torn
is it a small or big spring? 1.8" vs 2.3"
