Changing front A arm bushings to Whiteline
Department Of Boost
Alpha Geek
Haven't done a set yet... but the look a little easier to do. Maybe Red Devil can shed some light?
Oh, I've done them. They are not as easy. At least the way I did them wasn't. The knurled section has to be cut off of the A-arm. It's a PITA to do without cutting into the arm.
I was wondering if you had a trick.
robz
Could that inner sleeve not be pressed off of the arm? (assuming you have access to a press). I have the prothane front/rear bushings which are essentially the same design, I'm trying to game plan the install as well.
Red_Devil
Quality.Power.Sound
SoCal
I dont think there is any real trick to doing this easily. It just flat out sucks...
Department Of Boost
Alpha Geek
We tried rigging them up in the press and it just wasn't working. One, nothing is flat/straight in the plane you need it to be so there is effectively nothing to press against without it walking out of the press. The we made a 3/8" thick steel wedge/plate deal to fit behind the bushing and all we managed to do was bend the plate, LOL!
Yep, it pretty much sucks. Well worth it, the additional steering feel and caster are FANTASTIC. But it's a PITA.
Shotokan1509
CT
Interesting! Loving the whiteline LCA set on my subie, and their customer service is excellent
voodoo
How much of an NVH increase can be expected from these bushings. I ask because my car, for now at least, is mostly a daily driver.
908ssp
Michigan
No increase in NVH noticeable in my car from the replaced A arm bushings. But it might be masked by slightly louder exhaust and prothan type motor mounts.
a50cobra
Orlando, FL
Does anyone know if the post on the LCA rear mount is solid steel or hollow tube?
Hunter, if I understand your question, you are referring to the "shaft"/mount that holds the larger bushing on the rear of the arm?
If so, it is solid for about the first "half" then hollow the last "half"/end. About 1.4" of the 2.7" is hollow. The wall thickness is about .175"-.200." Hope that makes sense.
Here's a picture of a 2012 arm. It's a close up looking down into the rear bushing.
