Rygen
I can break any motor!
- Joined
- Jul 17, 2007
- Posts
- 499
- Reaction score
- 2
Finally have some some info to post here. I got the car back, and been slowly dialing it in. Started on the local 1/8th track at 7.7's, then whittled it down to two 7.55 passes with DA's in the 2200 range (track prep sucks ad OD on wednesday night). This is all on foot brake.
Then yesterday at Cecil, with a DA of 1726, continued to dial in the car. In the 1/4 before, at MIR with a DA of 2200-2300, the car went 11.92. Finally starting to used to the new stall and with foot brake, launching at 2800 (still not launching with significant boost, maybe 1lb).
So the car went [email protected] w/1.65 60ft and then an hour later went [email protected] w/1.64 60ft. I think with better air, and bringing down the 60ft to a 1.5x, I can see a 11.5 or 11.4 pass.
This is at 8.5lbs of boost. Haven t tried the trans brake yet, but that should let me launch with boost. Need to toy around with tire pressure..but leaning towards a set of tokicos all the way around if I cant get it dialed in more by lowering the psi.
Got some data logs of the passes too which should help for future visits as well.
Slip here:
Slip here:
