I just had a Spec Stage 2+ installed on my car. I also had the slave cylinder replaced while they were at it. When I picked up the car I noticed the pedal engage/disengage point is way different than it use to be. Now the clutch is fully engaged almost as soon as it comes off the floor. And there is some slop at the top of the pedal travel. I mean when you release it fully (at the top) the pedal will still come up slightly if you pull on it. I don't remember that being there before. Is all this normal for the new clutch?
I ran a search on clutch adjustment and found there is none. Basically it is what it is.
Thanks
Randy
Thanks
Randy
