he's talking about the 9" and anti roll bar setup in the above pics .... i think
yes i know. It wouldnt interfere with the exhaust at all. Its using the stock mounting points and the exhaust pipes go OVER the axle, not under it completely bypassing the anti roll bar
not to mention on FRPP's site it says works with regular GT's
lol shit don't matter to me either way im running dumps and could never afford a frpp rear end![]()
that kit is a little pricey. i can save someone some cash on it with free shipping. However if you already have uppers and lowers you might as well just get a steeda or BMR anit roll kit and be done. unfortunatly FRPP does not break up kits
Well the big advantage I see is that you could drop the links off street use if you were so inclined...( even though I have never dropped mine and run it on the street all the time without trouble) one might like it a bit better as the car wont sit straight up in the corners.....but it has not really seemed an issue with the 05 plus cars like it was on the older cars
kool kool man i will be putting mine in but im also changing 4-5 other things too so my " testing " will not be too accurate as far as these go
You leave the front one stock?
U can rotate those springs and get a little more or less. Al though there is a correct way to do it according to companies like steeda and such i noticed that whether you had the hook outboard or inboard made a difference
Why call ford?
Call Dave at TeamZ Motorsports If you dont believe me.
Team Z did all the suspension work for the cars.
http://www.teamzmotorsports.net/
Tell them Matt Stanford sent you. LOL (Matt and Dave Are friends)
I got the springs, arrived a couple days ago. Next weekend when I put them in, I will document the ride height change.
Also, since I will be going to the track again with no other changes, I will report back what my 60' times end up doing....
