cometic 94mm head gaskets 4.6 or 5.4
sportinawoody
Piedmont area , N.C.
brand new but package has been opened. part# C5503-030 & c5502-030 .030" thick. cleaning out parts little by little. 200 shipped
sportinawoody
just double checked, these will work on standard 3v aluminum blocks with no issues but should be accounted for when determining compression ratio
my07silvergt
HOLD ON TO YOUR PANTIES
Austin, TX
How much would this affect CR? And pardon my stupid question but would it increase or decrease CR?
lito
Caracas, Venezuela
94mm is their standard bore size, they don't make 92mm as the felpro/stock ones.
0.030 is a little thinner than stock which is usually around 0.032-0.036 but they have a bigger diameter, ending CR is close as an stock one.
Big bore cometic are 95.5 or 96mm I don't recall exact numbers..
05stroker
Never enough power guy!
Bullard Tx.
I decided to wait for the 92mm Ford overbore I have on the way. Good luck with the sale.
