Complete 4R70W Swap for S197
Kevin@PMP
Concord, NC
I have a slightly used complete 4R70W swap for S197 for $2800 local pickup.
Includes:
Trans built to hold 750hp, only a few hundred miles on it, has a manual valve body currently installed
2400 Stall Torque Converter
SFI Flexplate and ARP bolts
Large Aluminum Trans Cooler including all stainless AN lines and fittings
One Piece Driveshaft and Pinion Yoke
B&M Hammer Shifter (needs a new shifter cable)
Transmission Crossmember
Lokar Stainless Dipstick
Also included is a brand nedw Lentech transbrake ($900 value)
The only things you need are a bellhousing block plate and the shifter cable. Optionally you could change your pedal assembly and add a deep aluminum pan. I can provide all of these parts at competitive prices as well if interested.
Email me at [email protected] if interested.
KIMMER
Admin
You guys always have some killer ass deals! I can't believe this isn't gone already?
Chris06GT
Dragging LS A..
Alabama
That is cheap!!! Working at a converter/trans shop, I can relate to the cut Kevin is taking on this...especially after throwing in the Lentech transbrake....Good luck with the sale Kevin!!! Someone should grab this...
