brian m
I have a 2006 V6. It recently has been overheating. The cooling fan doesn't appear to be turning on. I've tried turning the AC on max but the fan still doesn't turn on.
The wiring harness, plug and cooling fan motor resistor all appear in good order with no signs of burning or wear.
I tested all the relays in the horn slot and all work. Fuses F3 (40A) and F40 (15A) are good.
So, I tried this...
My understanding is the pin 85 on the high speed relay creates a ground when called upon by the PCM. I recently tested pin 85 by connecting a light tester to the positive battery terminal, turned the AC to max (which should initiate a ground), and tested the pin - the light didn't light. That would indicate the ground wasn't created - correct? And that the PCM didn't send the signal? Thus a bad PCM?
Again, all relays and fuses check out.
Any thoughts are greatly appreciated. Thanks
So, I tried this...
