Corbeau Harness bar
SoundGuyDave
This Space For Rent
Belt stretch, and angular pull. Most harness manufacturers recommend crossing the belts if you have over "X" length (IIRC 15", but look it up for safety's sake!) past your shoulders. Think of it this way: A 5* deflection with a run of 10" is basically nothing, but a 5* deflection with a 60" run (back over the harness bar then down) could be enough deflection to have the belts slip right off your shoulders... That WOULD be a Bad Thing. Not saying it WILL happen, but it could. If there's only one mount point, then it's a single-failure point, and I would think hard about it. That's effectively turning the shoulder harness into a "Y" harness, which is illegal in every race tech book that I've seen. If, on the other hand, the mount points are offset to one side behind the seat, then you have an angular pull, and that's just as bad. Best would be for them to be wide, like the stock locations for the rear belts, and cross them going over the bar. That would leave just the stretch issue, assuming your wider mounts are roughly equidistant from the front seat centerline, which they may or may not be.
Kris_H
Chino Hills, CA
Got mine today. Disassembled the factory seatbelt feed...does everyone else have two spacers per side? I superglued mine together to make it easier to feed the bolt through. Going to take a crack at installing it tomorrow. :)
dafridgea
NYC
After the '2005-09 Mustang Corbeau Harness Bar' is mounted are the stock seatbelts available?
Gray Ghost GT
Road Racing Fanatic!
Madison, AL
I have the Corbeau Harness Bar installed in my '09. You can use your OEM seat belts with no problem. In fact, its designed to allow you to use either your stock belts or harnesses.
dafridgea
NYC
That's great to know. Thanks vey much!
ArizonaGT
Road Course Member
Phoenix, AZ
I haven't come across the restriction yet for HPDE with the 7 clubs that I run with. No problem using a harness bar without a roll bar/cage, but always best to read the rules of the club you're participating with.
Clubs might not have a problem with it, but good luck if shit actually hits the fan on/off track.
