Low Dogg
I was just thinking, with all the improvements made too the 2015 coyote engine, how hard would the swap be into a 2014 GT.... I know you will need to swap the intake, to eliminate the charge motion plates, an a tune to deal with the mid-lock cam phasers.... But it seems like it would be a pretty straight forward swap. You would gain better rods, heads, bigger cams and valves, all of which is carry over from the Boss engines..... Install oil pump gears, an I think this motor will perform just as well as the Boss motor. Just a thought. Any ideas?
