fzr confused
- Joined
- May 26, 2013
- Posts
- 48
- Reaction score
- 0
i installed some CMS stage 1 cams (no limiters/lockouts) a few weeks back. shortly i had the front cam cap bolts back out, not sure why or how. anyway, that caused my pass cam to go over retarded and would kill the pass side of the engine. anyway, i got that fixed but before i figured it out i talked to bama the tech said "o, well this could be causing it" and he did a tweak to my tune. well, it didnt help since the bolts were backed out. i have done a few data logs with all the cam angle options selected and well, i have no idea what it SHOULD look like. anyone on here able to look them over and see if everything looks good? or maybe tell me min/max that i should be seeing? on the data logs with the problems the "cam angle cam 0" was min -2.49 and max 61.98 while cam angle cam 1 had a min of -1.62 and a max of 53.26. they stayed pretty close until you would rev it, and then the pass side would go way up to say 61.81 and the drivers side was at -1.31. the data logs after i bolted everything down again stay withing 1-2 of each other which i assume is good. the pass side has a min of -1.86 and a max of 46.61 and the drivers side min is -1.15 and a max of 46.64. they stay very close to each other the entire time.
does the numbers look right? i ask because when it was having the issue i could hear the VCT going whacko, and with the windows up and the radio off yesterday and today, i can MAYBE hear a similar sound, could also be me being paranoid.....what are the min and max supposed to be? why are my max numbers now in the 40's while before it was in the 50's (the good side)? the tune before they tweaked it seemed to have more power, but could also be a placebo....
