What was the issue with your LC-1?
It never read right.. it was always 5-6 off or most of the time showing 16-22 at wot.. haha
I tried replacing the 02 and that helped a little but it was off.. I tested it 2 days ago before I put in the autometer and it was showing me at 14.1 at 6K.
After auto meter I was at 11.2 or something like that.
Do you already have your mini din cable?
I went though the instructions a little but the 3 wires threw me off a little since only 2 are left for the auto meter. I guess one can be for the blue/black wire/ then blue(=) and then use the same engine ground. .. I think.. but on the din from sct it looks as if one of the wires is for analog 2(if used)
Get this cable,
http://www.tricktuners.com/product/9_PIN_DIN/SCT-Xcal2-Data-logging-plug/ or make your own (directions on the same site).
The formula to put into Livewire for that AM gauge if the BGD is set at 10.0 - 16.0 is 10+1.5*V or if set at 10.0 - 20.0 it's 10+2.5*V. You should keep it at 10.0 - 16.0 as that's narrow enough of a range to give you an accurate reading. Look at the AM directions on BGD adjustments and also the Data Logger Output Range information towards the bottom of the instructions.
even on their din it looks like 3 wires.. (red/gray/black).. in dumb ass versions..
1)buy din kit
2) connect the autometer blue(+sig input) to (? color) din wire
3) connect autometer blue/black(-sin input) to (? color) din wire
3) what do I do with the spare din wire? (not putting in my butt)
4) whip out laptop that already had livewire.. start it up
5) plug in xcal 2 in obd2 and now plug in the mini din thats connected to the autometer
6) once live link is up plug the usb to the xcal and lap top for reg datalogging and open my file with all the PIDs.
7) Now I will have to add another PID for the WB and thats just called analog 1? then once thats loaded I can set the BDG and other things by right clicking?
8) with laptop and tons of wires drive in a public place and boost to 16psi and record.. haha
