Excellent concept. Steeda makes a 'X' brace that does NOT require removal of the rear seats. Light weight, (think it was aprx 9-11 lbs shipping weight), made from 1 3/8" chromolly steel, and .083" wall thickness for the CM tubing.
I used the steeda rear STB, which is adjustable in length, uses spherical ends, and is welded into place. Laugh all you want, but the piece works. I used the front steeda STB, its adjustable in length, and clears my CAI and blower. It is mounted to all 4 strut tower bolts...on both ends of the stb. (steeda HD front strut mounts used ). Beauty is both front + rear STB's are removable...at either / both ends. That came in handy when replacing the TB and plugs on driver's side. The driver's side of the front STB was unbolted...and simply lifted up
While I was at it, also installed the steeda triangular subframe connectors, also made of CM tubing..and bolted em in, using blue thread locker, then also welded them in. Between the 2 x subframe connectors went the BMR rear tunnel brace (+ mating DS safety loop). The BMR rear tunnel brace sits just aft of the oem DS pillow block bearing on the oem ford 2 piece DS. The BMR rear tunnel brace is made from 1/4" thick DOM plate.
While on a roll, I installed the BMR front A arm brace, which sits just in front of the ford oem A arm brace ( which actually ties the rear of the oem K frame together). Steeda version is called a G trac brace. Then installed the steeda 14-16" long CM pair of front sway bar braces, which are mounted diagonally across each front corner.
Ok, laff all you want at the 'do-dads'... but when switching to several other local 2010 GT's, the difference is readily apparent..as in blatantly obvious. The front + back ends feel more....'solidified'
