Next up will be the pair of steeda chromolly braces for the front sway bar. Whiteline makes a similar product (both are for 05-10 cars only). I suppose those are semi useless too. Well, between the pair of steeda CM front sway bar braces, oem control arm brace, BMR A arm brace, and the steeda front CM STB, it sure as heck feels a lot different. I view the front STB over the eng, as closing off the 4th side of a rectangle.
Between the 5 additional braces.... + steeda HD strut mounts and steeda HD eng mounts, it feels more solid. Perhaps not very scientific, and a bit of... 'hip pocket engineering' but the car feels better. This is just the front end bracing mods.
Then the rear ( welded) stb, rear tunnel brace and pair of CM sub frame connectors..also welded in. I'm happy with the results, but you really need to put it all in, as each piece alone is contributing a small portion. I jump in any 4 of my local buddies bone stock (as in no additional braces, oem eng + strut mounts), I can tell the difference asap, real obvious. So at least in this case, all the bracing vs none at all, yes you can feel the difference.
Was it worth it, to me it was. I was up for a good experiment anyway. Since nobody locally had tried any of it, I decided to try it myself.
