decking heads
csracing
SE Wisconsin
Does anyone have a calculation to correlate how much material removed from the deck surface equals a certain amount of reduction in combustion chamber CCs on a stock 3V head?
csracing
SE Wisconsin
I'd like to be in the 46-48cc range. I see you got about 2cc's out of .020" so I'm figuring I'd need to be somewhere in the .035" range or more for what I need. Going to do some more calculations first I guess.
Thanks for the link.
05stroker
Never enough power guy!
Bullard Tx.
Np , I just wish I could be more help. I was not able to find any data when I looked into this and just started taking it off bit by bit till I was where I wanted to be.
Fullboogie
King of the Ski - OG Jr.
Houston
Keep in mind that decking the heads affects other things, such as the intake manifold.
csracing
SE Wisconsin
Thanks. I had considered that so I drew up a representation of the block and cylinder heads in AutoCAD. Decking the heads 0.030" moves the centerline of the intake manifold bolts about 0.020" total, so about 0.010" per side.
csracing
SE Wisconsin
I had the heads decked 0.040" after I modeled the combustion chambers in 3D and played with numbers. I was targeting 46cc's and after having the heads milled, I'm measuring them to be dead on 46cc's. I unshrouded the valves before I sent them to the machine shop so keep that in mind. I actually increased the volume of the chambers a bit before they were milled.
Wes06
hmm, the cam is slightly closer to the crank, so assuming the chain links are the same etc. the cam sprocket will be ever so slightly retarded in timing.
However being adjustable it should be able to go back to normal range <except when fully retarded/advanced> Unless you have one of those fancy lockout gears thats adjustable
atleast thats how I could see it changing the cam timing
