driveshaft/clutch clunking around type of noise. never had it till i had the true trac installed...would a bad gear job cause this type of noise potentially
Is the sound only when moving? If so it could be a bad gear install. You could check and see if there is any movement in the pinion
Do you only get the noise when using the clutch or gettin on or off the gas?
Do you hear it when coasting down?
Knowing the shop that did the install, I would double check all their work. They were rough on my car, one of the reasons I will never go back!
Yeah I would pull the cover and check everything, being you have a true trac it wont cost much to put new gear lube in (hope they didnt put syn oil in it) check all the bolts on the diff (truetrac's are known for the bolts loosing up) and gears and look at the wear. Did you check to see if there was any excess play in the pinion?
mine makes a ton of noise, had the shop check it twice, the owner said yes its noisier then most, but nothing sounded like trouble. Also once you change the stock suspension and DS the harmonics get amplified.
If you are using the stock drive shaft I would check the support bolts that hold the d/s up behind the trans just to make sure they are not loose.
Bad gear install...I really doubt that even sittin here!
The clunk you are describing to be a bad install would mean WAY to much back/lash.
If the pinion pre-load was off much at all you would also have a horrible wine or howl
so to get the pinion to clunk it would really have to be phucked!
Grab the D-shaft and check the amount of play there is in the diff, it could very well
feel as though there is 100,000 of back/lash on the ring gear, most likely this is not the case,
all the play will be in the Trutrac!!
Other than a bad upper control arm or U-joint that Trutrac is most likely the problem!
You should also be running standard 75/140 gear oil.
Lets us know what you find.
Gene
Gene
I use to have a tru trac in a 01 bullitt. It made a horrible loud pitch grinding sound when I shifted hard. It performed great but just made a lot of noise.
this might not be it but if it clunks when you take off and shift it could be a lca bushing,been there.look all around the bushing and you can see if it's torn and hanging out.process of elimanation.
