E boost 2
one eyed willy
Pizzle fo shizzle
Lakeland FL
I know this is not a specific S&H thing, but will the eboost 2 control boost in different gears? How does it know what gear your in? Looking to lower the boost in lower gears, specifically in 1st gear.
lito
Caracas, Venezuela
Is for a sequential transmission basically, if you reset it before every pass it will work, you can even use the clutch to make it count the shifts, you can assign boost groups to gears.
Yes, it can, you would need to put switches on the shifter/trans to switch boost groups and like lito said can work as well. There is info in the user guide on their website.
